Horlogerie
·Speedy with water damage
Whenever you receive a watch with water damage, you have to expect the worse. While the outside may look not so bad, the inside is where the real damage is done. Water typically enters through the stem or in this case the pushers as well.
The stem goes to the dial side and it will carry the water right to the hands and hour wheel and cannon pinion. It can also migrate through the crown wheel to the top of the movement and various other parts.
As I took the watch apart, the extent of the damage became apparent, lots of it...
View of the mainplate, dial side
View of mainplate, top side
Barrel bridge
The movement in pieces in the tray, waiting for a cleaning
Many parts were damaged beyond repair, most ferrous parts had some type of rust damage, and I inspected them all and as long as the acting surfaces were not rusted, I re-used the parts, after a good clean and rust removal.
Overall I needed a number of parts, including a new balance staff, the bottom pivot on the old staff had rusted away.
Price for a new staff (only the staff, no balance, hairspring or roller table): $125.00 !!! ouch
So the understanding from the customer was, I will do the work at the best of my ability, if for some reason when I have completed the work the movement doesn't run well, then it may be beyond repair. Happily the customer was on-side and said that if it all went south, he would accept the risk and flog the watch to try and recoup his costs...that attitude goes a long way to build up trust and confidence in each other.
Here's what I was able to do regarding restoration...
Part of the problem may have been related to the pusher seals, check out what I found when I took them apart, two different types of seals, the standard o'ring and another white coloured type of o'ring/grommet, which doesn't look very waterproof, I have no idea why they were different, if one was replaced, or if someone replaced the seals only. The customer wanted new pushers and they were installed. The pushers were replaced not due to the water ingress concern (I stock and can replace the o'rings, restoring intregrity) but because one of them had a big gouge in it, looks like someone got a bit too close to a grinding wheel...
Amazingly, after all the work (and there was a lot of it taking much time) the watch ran really well on the analyzer, and the customer was very happy with the results, so was I...
Rob
Barrel bridge
Rob
