Hello everybody. Since I'm new here I'll take advantage of Speedy Tuesday to show how to make a two piece strap out of a NATO strap for a DSOTM. The first part is to cut the NATO strap in two pieces (obviously). You should use the 12h piece of the original strap as a guide for length. You'll need to have a slightly longer piece in order to fold it afterward. Then you should fold the extra length and stick it after burning the tip with a lighter (or flamethrower if you feel okay with it) After this part, I'd advice you to sew the fold for added security. I only did it on the black parts. Now repeat for the other side. Then to adjust the length of the other strap, you can use a coin as a template and once again burn the tip with the flame of you choice. I chose to let the metal passers free so I can adjust them however I want to. Mandatory wrist shot: Best regards José
Come on guys... This guy is chopping up a perfectly good NATO for us... taking pics of the process, and not s single like ??? It's not like you have to hand a £10 note over
Thanks everyone! @oddboy I don't own a leather NATO strap, but I may try something with a leather rifle strap when I'll get some freetime.
