Both of these parts are still readily available from Omega. If your watchmaker is sending you out on a hunt for parts, you might want to consider another watchmaker...
By the way, most cases of "hour recorder creep" or "chrono creep" do not require replacement parts, and often not even any adjustments. It's typically poor servicing practices, lack of understanding the way things should work, or a lubrication fault.
