Ok, I recapped today (it was a bit too late yesterday
) and would like to give anyone interested a guideline on how I managed to get the links back in. Again, as I was too tired and frustrated yesterday
I did not make any photos of the "progress" so I tried to illustrate with a small graphic which is hopefully kind of understandable.
As outlined above, I have no real recommendation of how to get the springbars out so the explanation below focuses on getting it back in:
1. Turn the small polished 2nd and 4th link (red circles) up in a 90 degree angle.
2. Place the third (middle) link (blue rectangle) in the middle.
3.Push the springbar (green) through links 2, 3 and 4 so that only the movable ends of the springbar look out on each side.
4. Press the combination of links and springbar back in links 1 and 5. This sounds easier as it is because if you press in the springbar on one side it slightly pops out on the other side and it is difficult to use the springbar tool to get it back in on the second side because there is no real gap between the single links. Still it will probably only work going from one side to the other. I only managed to squeeze it back in using WD 40 lube.
Its probably best to do this with the bracelet lying on solid ground, however, depending on how lose the links are they can certainly fall down from the 90 degree position (first step). I also tried putting it sideways in a link removal form but then certainly in step 3 the springbar easily slips through.
And - in contrast to the image below - I recommend working on the backside of the bracelet in order to avoid scratches on the front when pressing the links back in (step 4).
I hope this helps anyone to save some time. Give me a note if you mange to shorten the bracelet by two links in less than 2 hours
Best, Thomas
