SEIKO A159 LCD complete replacement module
Hello all - anyone help with sourcing a replacement module for the above (please excuse the terminology if incorrect). I've had this watch from new and I'd like to get it back up and running for sentimental reasons. If not replacement then possible repair, although its damaged due to battery leakage
Thanks..........
I think you should compare prices and check if buying a used watch for the module isn't much cheaper. If you're attached to the case/bracelet, you could just swap everything else.
It's a difficult philosophical question because if you think about it, if you swap every part, would it be the same watch? What do you need to keep to feel it's the same watch? If it were analog, I would reckon the dial/case. And possibly bracelet if it's nice.
