My parents recently found my grandfather's Omega Speedmaster while cleaning out some long-forgotten boxes.
Lucky me, being his namesake, they gave it to me for my birthday in September. As it needs work, I took it to Govberg Jewelers in Philly for an estimate on a repair. After sending it off to the Omega factor for an inspection, I was given the following info:
Complete Maintenance Service (mechanical and automatic)
A Complete Maintenance Service includes:
* Complete disassembly of the watch case, bracelet, and movement.
* Inspect movement parts for wear
* Replace all worn or rusty movement parts with genuine replacement parts
* Ultrasonically clean all movement parts
* Reassemble and lubricate using recommended lubricants
* Electronically calibrate the movement and reinsert into the case
* Inspect and replace gaskets
* Pressure tested
* Time test for accuracy
New hand kit: Included with service.
-Hands are flaking and worn out.
Refinishing will be completed to the best possible condition.
Total amount required is $985 plus 8% tax.
Optional work: Additional to the total required amount above.
-New Black dial: $285
-Luminous material on the dial faded and discolored.
Two year warranty included with the service. Estimated completion date is 9-12 weeks from the approval date.
If repair is declined there will be a shipping and handling fee of $75 plus 8% tax.
As I don't have $1300+ floating around, I declined the repair/restoration. The watch does run, and the stopwatch function works, but that's it. The bottom button doesn't respond to pressing. An appraisal would be included if I opted for the repair, but that sounds kind of weird.
I'm sure I could just get it appraised for current value, correct? I'm not even sure of the year and I don't want to open the case to find it. I'm guessing it's a '69 or '70, based on info I've found regarding the back of the case. He passed in '80 so that would be about right for when he bought it. I also have found that this is a "ladies" band on the watch, which seems right for my grandfather as he had "dainty" wrists (my mom's words, not mine).
I've attached a couple of pics. If anyone could suggest where I begin in terms of information, that would be great.
If anyone can offer advice on a reputable place to go in/near Philly that could do a trustworthy and reasonable appraisal, that would be great! I'd love to get it repaired/restored eventually as well, but is the price quoted above fair?
Thanks in advance,
Alan
