Seeking Help in re: 1950s hand-wind, 2-4-6-8-10 dial
(I'm reposting this with more information.)
This watch came in to my possession through my family. I have a few questions:
1) I know that it's nothing special, but is it worth servicing? What kind of performance can I expect after the servicing? I find the watch relatively attractive.
2) Were all Omega watches marketed as part of "lines" (Seamaster, Constellation)?
3) Where would this watch have been in the Omega line-up?
Here are the essentials:
1) Case is steel, 33mm, with 16mm lugs;
2) Signed crown;
3) Dial is patinated, with some tiny hairline cracks, visible in the photos;
4) It runs -2 minutes per day, except when it stops;
5) At best it has a 40+ hour reserve;
6) A virtually identical watch was sold on wannabuyawatch.com, where it is described as "Vintage man’s stainless steel Omega ref 2667-1 circa 1952" with a caliber 420 movement (https://wannabuyawatch.com/product/omega-stainless-steel-ref-2667-1-circa-1952/);
7) Here's another one, with replaced (?) hands and crown: https://www.mywatchmart.com/listing/253726-fs-omega-vintage-w-caliber-420-movement-cheap/ .
I have not been to a watchmaker to open the case, so no serial number.
Welcome
Unmarked "Seamaster" with the screw back case, early 50's
Without seeing the movement, I'd say service and wear it, nice heirlume.
Document any Family information you can and add your information and then pass it on as time passes.
Just clean the case......Do Not Polish off all those nice, original line-angles at the lug area.
Refrain from winding if you do not service it to keep from damaging the movement parts that need to be cleaned and oiled.
A sympathetic rehab and a service and I'd be tickled to wear that watch.
TexOmega speaks truth.
Welcome to the Forum.
