hi all! Ive just finished a project but am reluctant on installing the crystal. It has an external tension ring which i have not seen before. Can i just use the Press tool Or do i have to find the crystal compressor tool? Thanks!
Looks to me like you've got it upside down and inside out. What makes you think it belongs on the outside as you have it?
Tension ring (also referred to as armored) crystals are pressed in using a press like you have shown. However as others have pointed out, the ring goes in the groove on the inside of the crystal, not on the outside. Cheers, Al
Wow guys Thanks so much i didnt even Think about that configuration! And the press worked just fine! You all just helped me to get to the next step! Thanks again
