Just commenting on your post that a 145006 case would have an 861 inside - that case is for a 321, not an 861. So contrary to the post I quoted above, the case did change.
When cases look "nearly identical" that doesn't mean they are in fact identical. These two cases use different crystals, case tube, pushers, enlargements rings, case back, etc. so they are definitely not the same case.
