Hi Guys,
I have a 1999 Seamaster Jacques Moyal with a 32mm crown.
I want to replace the strap with a rubber strap, however the distance between the lugs is 18mm. If I use a straight strap, it looks too thin and more suited for a woman. Is there such a thing as a rubber strap that is 18mm at the tabs, tapering out to 20mm?
I have one, but looking for a flat strap and not something with ridges or bridges in the strap which makes it look ugly.
Any ideas where to but something decent?
Hi Guys, as per my previous post, as you can see I like the flat style strap, but the distance between the lugs is 18mm. The ugly rubber strap in the photos is actually 25mm wide, but connects between the lugs perfectly. Can anyone help and advise where I can get a similar strap and width to the ugly strap, but in a flat version. I would love to add a modern twist to this beautiful watch if you can help me please. Cheers Iain
