Hi Chris,
Something I will recommend is that when you are supporting the pinion for the sweep seconds hand, and the friction spring is in place, that you protect the spring from being damaged by inserting a piece of old mainspring between the pinion and spring as shown here:
Not sure if you have a timing machine or not to check the amplitude, but preventing the spring from being damaged like is shown above will help make adjusting the friction easier in my experience (aside from being good practice not to cause any damage while working on the watch).
