Thanks Francois - I suspect someone tried to tighten the hand with a triangular stake rather than the correct tool (or lathe collet). The triangular stake raises three "burrs" around a hole and is intended for tightening roller tables but, we don't like doing things like that! Only really for
emergencies...
Correct tightening tool (unless you want to tighten in your lathe collet which is also fine) is this and it comes with about 16 collets of different sizes. I use it a lot as I do a lot of vintage watches.
It's very chewed up - you should be able to see a pinion in the middle of the dial, like this and this is where the second hand is mounted:
What you're looking at there is the left hand end of the upper part in this picture.
I see a readily available yellow gold plated Omega hand (listed for a 14763 as far as I can see) at 12.75 mm and will have a look to see if I have anything shorter but that's short for a 562 (550 series watch). A new hand is about 20 quid. I am afraid that your watch looks like it has been re-dialled and that may be why the second hand is shorter, because the tick marks are on too small a radius. I could be wrong about the re-dial aspect and it make no difference whatsoever if you like the watch as is.
I'm in Somerset, where are you?
Cheers, Chris
