  1. browncow Oct 27, 2017
    Hi everyone,
    I got myself into trouble again.
    For no rthyme or reason, I swapped out the working-perfectly-fine existing Omega bracelet on my ST166.093 SMP1000m to try a Strapcode bracelet.
    While I was running, a pin on the Strapcode broke and the watch went flying, and consequently the crown/stem broke.
    So now I need a replacement crown.
    If my research is right, it should be part number 069ST43199, but a search on Ofrei and Ebay came up fruitless.
    Does anyone know where I can source for this crown?
    Any help would be much appreciated.
    Thanks all!
    ben
    Singapore
  2. No Mercy Oct 27, 2017
    Found it on CousinUK:
  3. TsoloT Oct 27, 2017
    That will teach you to mess with perfection this watch was made for the mesh anything else is sacrilegious
    browncow likes this.
  4. TsoloT Oct 27, 2017
    Can we see the watch at least please
  5. browncow Oct 27, 2017
    Thanks, No Mercy!!!
    And yes, TsoloT, my decision not to use the mesh bracelet has caused me endless trouble!!!
    Here it is on a Omega 1159 bracelet.
    [​IMG]
    TsoloT likes this.
  6. TsoloT Oct 27, 2017
    Very nice example did you build it or did you buy it built up
    And the mesh is the way to go
  7. TsoloT Oct 27, 2017
    Did a small photo for you as inspiration
  8. TsoloT Oct 27, 2017
    This is a build up as well
  9. browncow Oct 27, 2017
    Bought it built up, I'm afraid!
    Originals are apparently very rare.
  10. TsoloT Oct 27, 2017
    Well your bezel is right
    I will post an original
  11. TsoloT Oct 27, 2017
    This is an original which is a prototype for the first set of 5000
    The first is mine the second is the museum
    The third is the case numbers on this which was for Comex
    895B813E-CD93-4DE8-A2F0-19E5059EAAB3.jpeg 68032C3F-4C42-4D35-AA8A-663E33BE5472.jpeg 1F3DB9C9-B443-4F5D-A96A-C9DFE3038B05.jpeg
  12. TsoloT Oct 27, 2017
    The mesh bracelet with small clasp is indicating a prototype as it is special for divers only no adjustment for retailers as it uses the neoprene extension
