Railmaster Trilogy Bracelet Question
Hi all,
I recently picked up the Railmaster Trilogy and am loving the watch but cannot seem to get the fit quite right on the bracelet, even with the small amount of micro-adjustment in the clasp. Taking the micro-adjustment all the way out still leaves the bracelet a hair tight, but adding a link leaves it a bit too loose. I feel like a half link would do the trick, but spoke to my local boutique and understand that half links were never made for this model.
So, I’ve searched the forum and have seen that the 321 bracelet will work, but I’m curious if I’ll end up with the same fit issue due to the lack of micro-adjustment on that bracelet? Does anyone know of a half link from another model that would work with the Railmaster Trilogy or have an alternate suggestion? Thanks!
How wide is the middle link in mm's and how wide are the replaceable links overall? There may be links from other bracelets that fit. If you get those two measurements I may be able to make suggestions.
Hey, thanks for your help! It looks to me like the center link is 12mm wide and overall each link is 18mm wide.
Dang. I'm not sure what to tell you. The 38mm Aqua Terra has a 10mm wide center link. The 41mm Aqua Terra has an 11mm wide center link. The Heritage 300 has a 10.5mm wide center link. I'm not sure what, if any, bracelet has a 12mm wide center link. I think the Ed White is 10mm wide at the center link. I was thinking of you finding a half link, which would give you flexibility in sizing but would be way cheaper than finding a new bracelet.
I've read the Ed White bracelet fits the trilogy Seamaster so perhaps it will also fit the Railmaster. I know they make half links for the Ed White.
I appreciate your help nonetheless!
If the Ed White bracelet has half links then that will probably do the trick, I’m fairly certain the bracelet will work with the Railmaster Trilogy based on other posts I’ve seen.
If the Ed White doesn't have half links you should still be fine if you're getting the entire bracelet as the clasp has two micro-adjust holes. You are bound to get the right fit.
If you don't mind modifying your clasp you can have a local Goldsmith or Jeweler drill an additional micro adjust hole in the clasp.
