Quick question. Regulate.
I agree that it's not likely to be helpful for the OP to mess with the regulator, but he does have a point when he says that it's his watch, and it's his choice if he wants to tinker with it. Obviously if would be best to do this with an inexpensive watch.
My suggestion to him is to do things in a very careful way to avoid any damage. We often see scratched balance cocks because something metallic was used to adjust the regulator; this looks ugly and is a clear signature that the watch has been tampered with. So maybe use a wooden toothpick or something like that, but not a delicate tip that will break off and enter the movement. Also, he might want to hold the watch in a case holder so that everything is very steady, because it's very easy for the tool to slip and seriously damage something delicate in the movement. Along the same lines, unless he is young with excellent eyesight, it can be helpful to wear a magnifying visor so one can really see where the tool is going .Finally, when you open the case, it's very easy for debris and dust to enter the movement, which can end up causing more problems than the regulation will solve. Watchmakers work in a very clean place and have ways to gently remove debris with gentle puffs of air, but not from their mouths obviously. Nothing in the movement should be touched with the fingers.
If the OP can avoid damaging the movement and he can keep it clean, then any changes he makes should be reversible.
Thank you 😀 I used a plastic tool and I have magnifier. I had problems with dust before, when I bought it there was dust but I cleaned it up.
Done a lot to this watch 😀 it was always fast so I didn't messed it up in that way. Everything went great thus far.. I asked what glass I needed for it here a while ago "take it to a watchmaker" they had a que and wanted around 900 us dollars for Omega glas, around 600 for non Omega. Did it myself for 3$. Found out on another forum which glass I needed. And my case was not original according to a lot of people here, even tough I wrote it might be because of the old glass (that was wrong) made it look like the case was to big, but no that couldn't be it. That was it. AD confirmed it. Changing crown? Go to a watchmaker. Did it myself.
I don't think the time of the movement will change at all. But that was not the point.
OK, so you have a bee up your nose.
It's the internet.
If we were in our local pub together having a beer, and you happened to say, "hey mate, how do I regulate this little watch I have?".
I'd probably say "don't be stupid, do a little study about watchmaking and then do it, now buy me another beer!"
You seem to be a person who can adapt, improvise and overcome, but while engines and other big stuff are easy (even my local mechanic can do them), watches are totally different and require a new level of thinking, dexterity and skill.
Just stick with us, ask questions and we can help, but don't jack up when we respond with well founded feedback based on many many many years of experience (and in my case, a few fuckups because I didn't listen).
I've written about this before. I'm sick and I don't care if something else goes wrong. My health is more important than a watch. I wish I could drink beer without feeling like shit. But I can at least learn about my watch. I'm not going to buy another that's "better to try it out" on.
Please accept that I just wanted a simple answer, which I got. I don't need people telling me that I can't do stuff all the time. I can learn and if something goes wrong... That's it. It's not the end of the world. That's how I see things. A lot of people might see it differently but no need to try and make me change.
It is not a question of “you can’t change it yourself”. You can. The question is can you “improve” the accuracy of a watch that likely shows varying rates at varying times. You may change it, but can you improve it?
I wanted to know what A and R stand for. The reason for that is because when I tried to search for it, it gave me answers I didnt understand because English is not my 1st language. I didn't even ask if I could improve it
None so deaf as those who refuse to hear!
Like everyone that keeps writing to me in his thread then.
I wish you the best for your health.
Over and out.
None so condescending as those that think everyone else is an idiot.
In my mind the question is: Does the OP's watch need a service or not? If it does, then moving the regulator is not going to solve anything. But moving it is not going to destroy the movement, is it? So let him. He'll have to service the watch eventually.
Like the OP, I am relatively new to this hobby.
I understand that a movement should be running well and thought not to be in need of service if one wishes to regulate or adjust the watch oneself. If the watch is essentially "disposable," then have at it.
There are many tutorials to be viewed on Youtube and @ other places that may be helpful in learning about how a watch works and how to regulate and adjust.
Personally, I would not want to try and either regulate - or more carefully adjust a watch - without having a timegrapher available. Even with a timegrapher available, it takes patience to adjust a watch and without such a tool, it would take incredible luck to get things right. You'd have to pretty much make an infinitesimally small single adjustment to the regulator and then wait at least several hours to ascertain the effect. To know for sure whether you'd made an improvement could take a day or two.
All widely available and inexpensive timegraphers appear to be made by Weishi regardless of the brand on the front panel. At Amazon, they start off at around 135 USD.
Here is a tutorial that will be very helpful:
How to Use a Timegrapher WatchGuy UK
More good information here:
Adjusting Vintage Watches - Adjusting Tools: The Timing Machine
One thing I experienced as an amateur is that moving the regulator may sometimes move the mobile stud carrier (on the balance cock abutting the regulator) on watches that have mobile stud carriers. Once you move the mobile stud carrier, you will not be able to adjust the watch by simple trial and error without the benefit of a timegrapher.
Edit: The watch pictured by the OP has a fixed stud carrier, so that makes the process easier.
I am not an expert on anything related to watches. Anyone who reads this post and finds inaccuracy or bad advice within is encouraged to set me right.
Cheers,
Joe
