Here you go.
Step 1.
Stretch the bracelet slightly so that you can get the jaws of
fine tipped serrated pliers onto the "U" clip.
And then hold the bracelet and pull the clip out.
Step 2.
Pull the two parts of the bracelet apart by sliding one section from the other.
Step 3.
After removing enough links, push or slide the sections together over the U clip on one side, then set the opposite U clip in position.
Step 4.
Make sure the U clips are set to the outboard side of the centre leaf spring inside the link, and then push in to place with pegwood or other non-marking tool.
Good luck with it.
Cheers
Jim
