Caller, fascinating. I had no idea other 9300s behaved the same way. Maybe this really is "normal"? Does anyone have a 9300 that doesn't show this behavior?
Archer, I bought this watch used, so I have no AD I'm working with, I've just been working directly with Swatch, via FedEx. Every time I've called them about an issue, they always say to just send it in and let them look at it, regardless. And though the invoice says partial service, the red dot is intact. In fact, the last time I sent this waych for service (due to debris under the crystal), they cleaned it out and the red dot also remained intact, so they either replaced the dot with more red or they can remove the crystal without opening the case back (I'm sure you'd know if that's possible on this model).
