Hi, how about these parts: My guess: Second ex. case (no crown guard) with third ex. caseback (869120) Is the bezel original? Crystal OK? Can this be a transitional execution original arrangement or are the parts mixed? Thanks for your input!
That case does not look like a polerouter sub case. UG Sub cases (exec 1 and 2) do not have lugs drilled through. Similar cases are used by other houses such as Titus. The bezel is also a little suspicious. Although it is the same style, the font does not correspond to UG fonts. It is far too thick and looks a little messy too. However, it would be acceptable as a replacement. On a good note, the case back looks OK although serial and reference are missing ...
The fonts on the bezel look too thick Need better pictures of the side of the case to assess if it is a PRS case This case was recently sold on eBay- did you win it?
Did a very close look at the bezel after posting first, I'm 99% convinced the bezel is not original. This one from OF as comparison, compare how the "4" is touching the "0") As pointed out by @Diabolik before the case is not 1st or 2nd execution. Because of the above reasons I did not bid, I was mainly interested in the bezel
