Hi Is it possible to polish out scratches on a Polaris Palladium See photo)? Is it also possible on a steel / gold polaris? Thanks in advance Kind Regards
I have no doubt it can be done, but how much it will cost and the eventual outcome is moot. At least a couple of the scratches look fairly deep and to take the case back to a uniform depth may involve an unacceptable amount of material being removed. Also there is the risk of differential material removal during any polishing/buffing process as palladium and titanium have differing hardnesses. Finally, bear in mind that these did not come as polished, but rather had a matt finish (see attached image). I would suggest a skilled watchmaker with experience of these models would be best to further advise. However, I'd guess they are a very rare species. Failing that, a competent jeweller who has experience in working with and finishing these metals might be your best bet. Hope this helps
Pls leave it alone. You take the risk and send it in, it might turn out worse than it looks. Losing sleep over it? Then at least bring to Omega service center and hear their comments first.
