Hello All. Since the vintage Omega bug has becime almost viral, i stupidly took a jump with much research since the seller had a good reputation. Pls can you guys assist. 1. Wanting to know rough age and model number. 2. Is that caseback aftermarket? It just says waterproof which is surprising Here are the pics. Thank you
Late 60s early 70s, case back is typical for a Geneve of this vintage. Reference number will be on the inside of the case back, serial number will be on the movement.
