Having here a limited edition of the Perrelet Turbine with Double Rotor. Perrelet has claimed that they are the first makers of an automatic watch, and that's what they try to accent here. Another rotor, purely decorative, is put onto the dial, which from the slightest movement of the hand, it rotates like a... turbine. Hence the name of the model too, Perrelet Turbine. The case is 44mm, the crown is finished a-la-Dupont style, the bezel is ceramic and the case is DLC-coated. The rubber band is cut, but I am sure it is large enough to most of us. There are some very small hairlines on the bezel, near the 6-th position. The crystal is sapphire, and is AR-coated. It makes a very interesting color-changing effect under different angles. The watch comes with full box and documentations. However, the watch will be shipped separately first, and then the docs and the box. It is from a limited edition series from 888 pieces. This one is 288. Looking for $3800, negotiable, paypal and shipped worldwide. Here are some references about me here: https://omegaforums.net/threads/baoquang-recommended-seller.8020/ https://omegaforums.net/threads/baoquang-great-to-deal-with.17709/
