  1. Brook Oct 29, 2016
    For full disclosure, I posted my Speedy to sell on On the Dash last week and a couple of folks told me a couple parts are incorrect. After a few days, I pulled the posting and decided to keep it. It is not for sale now, but I would like to get the correct parts on it.
    I am looking for help on sourcing a correct crown and lower pusher. My existing crown is about 6.5mmX3mm and has the old omega insignia. Any idea on correct crown dimensions or part number? Also, need a part number for the pusher. I did not have much luck on Ofrei.
    One last point that I would appreciate some feedback on is the serial number. I was told that 18464xx was correct for 2998's, but not a -5. I checked Speedmaster 101 and it looks like this S/N would be okay for a -6. The gentleman who brought this to my attention, mentioned Moonwatch Only as his source. Are Omega serial numbers that precise in dating the watches? Can I be 99% sure my watch has a movement that did not come with it from the factory?
    Thanks in advance for the help and guidance.
    Brook
    rogart and TJH like this.
  2. Just Livin Oct 29, 2016
    According to MWO 18,419xxx to 18,645xxx would also be good for a 2998-5.
    You have an inside shot of the caseback?
  3. gemini4 Hoarder Of Speed et alia Oct 29, 2016
    Here is what you need
    Crown
    https://www.ebay.com/itm/142131151261Purchases made through these links may earn this site a commission from the eBay Partner Network
    Pusher
    https://www.ebay.com/itm/380875163477Purchases made through these links may earn this site a commission from the eBay Partner Network
    Your movement number is within the correct range, per MWO, for a 2998-5
    Good luck
    watchyouwant, bazamu, Dash1 and 4 others like this.
  4. oddboy Zero to Grail+2998 In Six Months Oct 29, 2016
    Crowns are tough. Theres a guy on ebay who sells railmaster crowns that look like speedy crowns but don't fit. A member here has been known to sell the same, but already adjusted. Real ones are very hard to find, and expensive.
    The pusher you want is, 086ST0023. Shouldn't be hard to find.
    marco and gemini4 like this.
  5. Just Livin Oct 29, 2016
    Edited Oct 29, 2016
  6. cicindela Steve @ ΩF Staff Member Oct 29, 2016
    I bought these in 2013 from Ofrei for $15.@
    Probably went up but worth giving them a call.
  7. gemini4 Hoarder Of Speed et alia Oct 29, 2016
    Ofrei has next to nothing these days. Cousins in the U.K. Stocks 086ST0023 at £45 each
    oddboy and watchknut like this.
  8. oddboy Zero to Grail+2998 In Six Months Oct 29, 2016
    And on ebay now and again. General*Vintage is a member here and might be able to help.
  9. Brook Oct 30, 2016
    Sorry all, I have the serial number wrong in my original post. It is 18946XX, for got the all important 9 as the third digit..........
    Thanks for the leads for the parts!!
    bassem abadan likes this.
  10. gemini4 Hoarder Of Speed et alia Oct 30, 2016
    As I have one in this range, I believe 18946xxx is a 2998-6 movement number. MWO indicates that this movement could have originated in a 2998-6, 61 or 62. Who knows how your's ended up with a 2998-5 caseback?? Swapped during a service. A leftover 5 caseback during 6 production. Omega was known for using up their available parts. These 2998 references (8 in total) were switched every few months and Omega did not excercise the greatest control over parts. You have a great watch and I wouldn't worry about it.
  11. Brook Oct 30, 2016
    Thank you very much and I have a hard time believing that Omega was all that better in keeping records than Rolex, Heuer or Breitling.
    Maybe the were? Is it worth it, and would a Certificate from the Archives tell me definitively ? Being from USA, don't know how I would get one....
    Again, thank you,
    Brook
  12. gemini4 Hoarder Of Speed et alia Oct 30, 2016
    You can try, look online or visit an Omega Boutique, but Omega's records (aka microfilms) are often not available for the 2998s.
  13. oddboy Zero to Grail+2998 In Six Months Oct 30, 2016
    Give it a shot, but I've never been able to get one for a watch below about 20,55xx,xxx.
    Also, the extracts don't specify the subreference. So all it would say is that it's a 2998 (not specifically a 2998-5), along with year of manufacture, and where it was delivered to.
    Another point of reference, speedmaster101 says:
    Serial Range: 1841 9xxx – 1894 5xxx
    As Gemini4 says, it's a nice watch. I wouldn't worry about it too much.
    bassem abadan and bazamu like this.
  14. bazamu wincer, not a bidder Oct 30, 2016
    Agree with all they've said above. In general, if a serial is close to the generally accepted range, I don't worry about nefarious origins / franken parts.
  15. jlambo Jan 21, 2018
  16. bassem abadan Aug 19, 2022
    hi,
    mx 321,seriall 18945129, 2998-5 back case.
    best reg
