  1. Pokkis Jan 12, 2017
    Hi, could someone tell me is there something strange in this Omega 1022 movement?
    It's ticking in a vintage Geneve I recently bought and I'm wondering shouldn't there be some ref. number also in the movement or not?
    Google pics search seems to find 1022 movements both with and without numbers on them...
    I attach also pics of case back and Omega bracelets numbers. What can one tell about them?
    IMG_20170112_144811.jpg IMG_20170112_144827.jpg IMG_20170112_144852.jpg IMG_20170112_144923.jpg
  2. efauser I ♥ karma!!! Jan 12, 2017
    I see 1022 on the movement, not sure what you're asking. The reference number is 366.0833 (inside the case back). If you do an internet search of that reference, you'll answer your own question. Since you provided no front shot, I'm just guessing.
  3. Pokkis Jan 12, 2017
    I did see that 1022 but should there be some other number visible in that movement also? Some quite similar movements seems to have but others do not. The watch is Geneve day-date automatic.
    Those case back and bracelet photos I attached basically to ask if those numbers can tell if they are originally from same watch or just assembled together from different watches...
    Here's the front.
  4. efauser I ♥ karma!!! Jan 12, 2017
    Pokkis likes this.
  5. Pokkis Jan 12, 2017
    Ok, that's good to hear. I didn't thought that little number inside that circle could be it but naturally it is.
    Still I'm wondering if there originally should be written Omega etc. like in this photo I found:
    Bravinho6 likes this.
  6. efauser I ♥ karma!!! Jan 12, 2017
    Sorry, I see what you're talking about. Something's up with that. Appears to be a replacement but I'll let those more knowledgeable about parts answer.
  7. jurisevac@ Jan 12, 2017
    Omega end tissot have collaboration in 70's so lots of movement was marked with less...only my point of view.
    Pokkis likes this.
  8. Archer Omega Qualified Watchmaker Jan 12, 2017
    Since several movements share the same bridge, it's likely a replacement that was made to be non-specific. I would not worry about it personally.
    Bravinho6 and Pokkis like this.
  9. Pokkis Jan 12, 2017
    Allright, that just might be the case here. That's a relief to hear!
    Watch isn't mint so it don't bother me much if it's only a non marked spare bridge that is been used at some point.
    Thank you all! I knew that you would know.
