: Hi all members i am selling this Omega Speedmaster Professional 105.003-64 : (You can read more about this model here: http://speedmaster101.com/105-003/ ) : The watch is in an very good condition. Case very clean with marks of time and the last of the straight lugs. : The engravings on the caseback look good. Bezel has faded to grey color and though it has some scratches, it is in very good condition. : This bezel has the DO90 which is correct for this watch. : Original plexy in very good condition with the Omega logo visible. : The stepped dial is in extremely good condition. The color has started changing to a very dark chocolate. As you can see from the pictures there are no "Professional" on the dial. This is also the case without a crown guards and the famous 321 caliber. Lume of the hands were changed in some point from the last woner. : Mechanically the watch is perfect after a full service. Keeping very good time, great power reserve. Chrono working as it should and resetting perfectly. : PRICE : €10000 + FEDEX shiping : More IMAGES: Just contact me and we will talk. : Watch and me are located in Portugal : Thanks all for viewing and OMEGAFORUM for this space
SORRYYY the owner is not the owner any more.... the watch as you can see is not the perfect Ed White and its again for sale. No problem.
Movemente and case. The movement have been discussed with SPACEFRUIT (omega forum member) "The movement, while in serial range and apparently in good condition, has a mechanism fitted to fix the adjuster on the balance cock. I have never seen this in any speedmaster, and nor in any calibre 321 I own. Just because I havent seen it does not make it a problem - the problem is proving that it is an Omega specification modification - I have to say I think it is not, and therfore I would consider the movement modified from standard." I give all the information about the watch that i heve, no surprises! But i´m selling and i have the watch in the condition that i have.
