Omega Speedmaster Pro 20mm Spring Bars
Sorry I meant to say 1.6mm for the Apollo 11 bracelet fit the speedy 3861.
Can you guys confirm that this is the only requirement to make the said bracelet fit the 3861?
The 1.6 mm bars are 21XX, so 2107 and 2108, etc.
Thanks Archer! Found the OEM 1.6 spring bars on ebay but soooo expensive. Will 1.5 work as well to fit the Apollo 11 bracelet on the new moon watch?
No idea...
1.5 will fit because that's the thickness and not the length but my question to you is, why aren't going for 1.8 in thickness which I believe is the correct thickness that Omega uses on Moonwatches? Did you try a 1.8mm one and it did not go through the end-piece?
It’s a bodge to make a bracelet that isn’t designed for the watch, fit. To me this is only asking for a watch to end up on the ground or worse, but to each his own.
