TomGW
路Have you tried on the Mk IV before? Is quite bulky and heavy, a bit more than the Mk II, and quite a lot more than the Speedmaster Professional (Moonwatch).
I have both the MKii and MKiv and don't notice much difference between them in terms of size or weight. The MKiv has a raised bezel, which is the main difference in shape and size. Are you sure you're not thinking of the MKiii, as it's a bit of a brute?
you are correct, brain fade here, what matters is timing something "per minute"
(which my dumb brain inevitably associated with "per hour", then by another f'ed-up piece of logic, "kilometers per hour"... thanks 馃槈 )
@TNTwatch
Yeah, the Tachy scale is just fractions of an hour, so timing a single occurrence of literally anything at all can be translated directly as 220, or, 90, or whatever, per hour. Dividing by 60 will therefore give you the per minute rate, or in the above example divide by 5, as you have already lumped 12 occurrences together as one unit.
