Omega Speedmaster “ Ed white”
I got mine in March 2025, and it immediately became my favorite watch. Sure, I love wearing my 3861 Speedy Pro on various leather straps and marvel at the hesalite dome. I also love my white dial 3861 on its bracelet for its elegance, but the Ed White is truly next level. As many others said, if I had to sell all my watches and I could only keep 1 watch, it would be my Ed White.
Thank you ! I went in and spent a while looking at it closely today. I took my 3861 in for a direct comparison . Despite the dials being at first glance very similar, closer inspection showed they are in fact quite different. Hard for me to explain exactly how, but the 321 disl looks a bit cleaner,more balanced if that’s the right word. It wears better too on my wrist/ I have 16.5 cm wrist and the speedy pro is at the limit of my comfort zone. Like you, I have a variety of straps I wear with the pro. But the 321 screams bracelet , to me anyway. A stunning piece overall.
I bought the 3861 when I didn't know anything about watches. As I learned more about the Moonwatch history and horological significance, I wanted the 321.
Now that I have both, I feel if I had the 321 first, I would never have bought the 3861.
Modernized elements of the 3861 (twisted lugs/bracelet/etc) look unattractive once you have a 321.
Did you buy it?
My opinion - The only people who should buy an Ed White are Speedmaster enthusiasts who knew they wanted the watch the moment they heard about it. If you need to be convinced it's better than the standard Moonwatch, I don't think it would be worth the premium price to you. And I would put myself in the latter category.
Give it some time. My tastes changed. I had to have a straight lug but now find the twisted more refined.
And my daily
And my daily
Yeah, honestly the 1861/3861 and the 321 have such different cases that they have a different 'vibe' to me. They are very similar watches, but because of the differences still have enough of a different feel to me that i wear them both. I can't put it into words, but I actually love them equally but differently.
That said, I just realized that my 6 Speedmasters are arranged 1861/3861/321 count as 3/2/1 😁
Once you see the differences they are hard to unsee. While worth owning both they very different.
To me, the 321 is classic and a symbol of great things past. It should always/only be worn on the OG flat-link bracelet.
The 3861, and other modern variants, are nicely inspired by the original and can be worn with many strap and bracelet options.
Maybe sort of like wearing a suit vs blazer and slacks...?
No one has mentioned the difference in size (39mm vs 42mm). The modern versions are at the outer limits of size for me.
YMMV.
YMMV.
Most of the size difference is "fake", as it includes the crown guards which don't really add anything to the size. Dial/bezel are basically identical size. They don't wear any differently imo.
The modern versions are more than inspired by, they are faithful descendents.
The twisted lyre lugs aren’t really modern. They’re original to the actual Moonwatch from 1969.
With the recent release of FOIS the gap between 321 and regular line has become very small, where beside the movement, the wearability is almost the same (case design and bracelet). Personally, I do not think the 321 movement should cost that much (double the cost).
On secondary market, the watch hardly retain value and sometimes for a mint condition it can be below MSRP which tells you something.
You should probably get the FOIS.
So you've never told us whether you bought the 321 or not. Yes, no, maybe?
I've been through the gamut, started in the 70's with a 321 which i wore until about 1990 when it was stolen from my locker at work. Had a variety of Breitlings, a Submariner and a Seiko phase until 2015 when my wife bought me a Hesalite 1861 which I wore until 2021when the 3861 Sapphire Sandwich came out, traded the 1861 as I preferred the accuracy, the fantastic bracelet and finally the ability to hack. Then i saw the White dial, waited about a year and went for it. Traded my black 3861 Sapphire Sandwich and never looked back. For me, it checked all the boxes, totally love it (see updated avatar!) Im 78, and I wear it everyday. It's now my only watch.
Obligatory wrist shot....
The Ed White is a watch you really need to feel in the metal to decide. Given its price tag, the watch doesn't make much sense on paper unless you care a lot about the 321 movement (whether for mechanical reason or the moon landing historical association), at least that was the case for me personally.
The standard moonwatch wears a bit better with it's slightly shorter lug-to-lug distance, thinner case and the additional crown guard actually makes it more balanced on the wrist. The Ed White wears taller, the movement is technically inferior to the 3861 and I personally prefer the Nixon bracelet with smaller links and on-the-fly adjustment clasp on the 3861 moonwatch.
However once I've tried on the 321 Ed White, all the above went out of the window. The Ed White is finished to a noticeably higher standard than the 3861/1861 moonwatch. The fit and finish of the case is top notch, the galvanized dial is sharp and clean, the long indices with slight patina shade superluminova is executed to the goldilock spot between vintage and modern, the lume works better in the dark. I had doubts about the ceramic bezel at first but the rich and crisp feel of the enamal lettering matches the high end finishing of the case very well. I put a FOIS bracelet on the watch so it has quick adjustment mechanism that comes in handy during summer.
The movement looks great mechanically, the finishing is good but not stunning (coming from JLC and Lange). The accuracy is so-so but the tactile feel of the pushers is definitely elevated from the 3861 and right up there with the top players. This is by no means a knock on 3861 as I think 3861 probably has the best pusher feel among cam chrono watches (even better than some column wheel chronos from major brands).
I seldomly wear my black 3861 Hesalite anymore after acquiring the 321, and the Ed White is now in a happy rotation with a white 3861. The 321 is like a sleeper watch, like a RS4/RS6 in the car world, it doesn't scream for attention but those in the know will know. If you want the ultmate modern Speedmaster in steel, this is it. Aside from accuracy, it does everything a modern 3861 speedmaster does, only better and more refined in every little detail. That said, I don't think owning both is redundant, the black 3861 retains more toolish vibe and can handle more beatings technically, which makes it a great life companion that carries the true spirit of a Speedmaster since 1957.
The doctor says OMEGA-3 is good for my health
About time to add some vintage spice in that box
I honestly thought about picking up an actual vintage Ed White, but the OB ended up coming through with the modern one before I could!
I'm pretty 'done' for a while unless something new/interesting comes up color scheme wise that is different enough.... That said, both of those are awesome.
Ha, just realised I hadn't said. It's a " not yet", but " almost certainly will". Just trying to decide which of my three goes to make room ( a speedster professional, a Grand Seiko SBGM 221 , and Railmaster 57). Deposit put down, but having to let one of the family go is proving difficult.
When i got my white Speedy, I looked at an Ed White, looked very nice and is definitely an exceptional watch. For me, three spoilers, really dislike faux patina, should have at least had COSC certification and because of the faithfulness to the 321 design, doesn't hack. Loved the overall feel and look through. When I placed the order for the White 3861, (took about 5 months) i, because of my long tenure at that AD, was offered a Snoopy. I looked carefully but ultimately walked away, the spoiler was the cartoon animated back instead of the regular display back. My grail Speedmaster is the earlier "Failure is not an option " version which now falls into the unobtanium price range. In comparison, the new White Speedmaster has everything I wanted or felt a need for in one watch. I had considered a Rolex Polar Explorer, but when actually trying one on, was disappointed by how clunky it looked and felt. Side by side with a White Speedmaster, it looks almost industrial compared to the subtle elegance of the Speedmaster. I won't get i into the absurdity of Rolex marketing with a multi-year wait to pay list price and instant availability of a "Certified Pre-owned" for several thousand over retail. Omega hit a home run with the white Speedy, happy to have been in the stands to catch one.
Great collection. Can anyone here put the new FOIS next to the 321?
For me, three spoilers...
Fun to read. Thanks for the thoughtful analysis. Great example of buy what you like and ignore the hype. Nothing wrong with buying the hype if you like it, but do it for you.
(Of course, now I want a white dialed speedy, contrary to what I just wrote.)
