Hello Members, I have a 1175 (no. 12) bracelet with 20mm end links. I would like to use this bracelet for my 19mm Speedmaster 105.003. Are there any 19 mm end links that would fit this bracelet? I have 19mm seen 636 and 560 end-links for sale on eBay would those end-links fit my bracelet? Cheers, Richard
Here's the best I can do for you. https://omegaforums.net/threads/from-7077-to-1171-18-vintage-seamaster-and-speedmaster-bracelets.45883/ Sadly there is no definitive bracelet guide. Probably too many makers and variances. But the thread above is a start. I'll google the case number I'm interested in for pictures. If I see a bracelet I try to find out if there's a shot of the clasp inner and the end links.
Maybe if you measure the width of the last link, you could find compatible ends to fit that piece. That's the bit that's most variable, and not well documented. Some 19mm ends to try: #6 #506 #617 #560
Have you had a look on Mstanga's bracelet chart? https://omegaforums.net/threads/vintage-speedmaster-bracelet-chart.29051/
Don’t mean to hijack the thread, but how does one connect endlinks to a bracelet? Do I need pins, and if so, where to buy, and does anyone have a part number?...
The end link, and the last piece of the bracelet are held together by the spring bar. No other parts needed.
