  1. Cal_321 Jan 31, 2018
    Does anyone have the exact measures of the correct tube (outer and inner) measures of the crown tube inside the case and also of a correct flat feet crown?
    I'm a little bit confused because the mounted service crown fits the tube but the flat feet cown not.
    Thanks
  2. mr_yossarian Jan 31, 2018
    Are you sure the flat feet originally came from a Speedmaster?
  3. Cal_321 Jan 31, 2018
    No but the outer measures are OK (6,7)...
  4. oddboy Zero to Grail+2998 In Six Months Jan 31, 2018
    https://omegaforums.net/threads/321-crown-replacement.51128/
    SpeedSea and mr_yossarian like this.
  5. Cal_321 Jan 31, 2018
    Thanks, I've seen this thread but my problem is the tube outer diameter (case side)...
    oddboy likes this.
  6. Archer Omega Qualified Watchmaker Jan 31, 2018
    If a correct replacement crown fits the case tube, and your other crown does not, it's not the case tube that's the problem...
    Cal_321 likes this.
  7. omegastar Jan 31, 2018
    Sometimes they don’t fit because the inner gasket has melted or because the inside is filled with gunk...
    Maybe it is not a Speedmaster crown but a Seamaster or Railmaster crown.
    Cal_321 likes this.
  8. Cal_321 Jan 31, 2018
    Yes, agree. I would like to figure this out so we can all participate...
  9. Archer Omega Qualified Watchmaker Jan 31, 2018
    What is the OD of the case tube on the watch you have?
    Note sure there is too much to figure out here - likely the wrong crown.
