  1. tomo Aug 2, 2015
    Here's a friends 105.012. Movement number is 245XXXX case back is stamped 105.012 65. My question is the dial looks off somehow. The font is too modern? The t's spaced wrong on the bottom? Any thoughts?[​IMG]
  2. tomo Aug 2, 2015
    I also noticed the pushers and crown are service parts but I do like the kinda faded look of the bezel. Ignore the obviously wrong bracelet.
  3. JohnSteed Aug 2, 2015
    Generally looks good. Pushers may have been changed, lower out too far. Hands also seem newer and likely changed over time. Dial very attractive to my eye. Dial may look 'off' as all the timers not zeroed and seem to be running/timing. Otherwise, dial & bezel looks good to my eye.
    You must have movement pics as you know the serial. If not, get pics to check out the movement, caseback reference etc., hesitate long and this will likely be gone....good luck!
  4. marturx Aug 3, 2015
    Very nice specimen. No need to worry about it
