I have a SM 300 ref. 166.024 that has the 300 script below Seamaster on the dial. On most SM300's I have seen the 300 is in line and after the Seamaster script, not below. Could this be a incorrect redial?
If you post pictures it will be significantly more helpful than just a text post. Also my want to read up on this: https://omegaforums.net/threads/vintage-omega-posting-guide.383/
Without clear photos, meaningful advice is difficult but from your description, the dial is incorrect.
Yes , that is how the script appears on my dial. I believe the example you show is a non date 165.024 model. Strange that it would also be redialed incorrectly. Now to find a correct 166.024 dial that is not a Watchco. Thank you.
