A number of problems can cause the symptom of the hands not setting. For this watch to have ended up in a second-hand store, you almost have to know that a prior owner had checked in to having it repaired and was shocked at what he (or she) heard! The watch was retired! If you were to check the retail price of a new equivalent ladie's Omega Quartz watch, you might decide this one is worth fixing up. But be prepared to shell out! Have it checked out by a watch repair shop, NOT the watch repair counter at your local Wal-Mart!
The problem with the hands not setting has nothing whatsoever to do with a low battery! The problem can be one of a number of problems. Crown loose on the stem, a broken intermediate setting pinion, broken minute wheel post, broken teeth in the setting pinion, broken pilot on the stem, rust, broken teeth in the minute pinion assembly, or a combination of several similar problems.
