Omega Seamaster Polaris Chronograph Ref. 378.0885 - Serial N
Hello everyone,
I recently acquired an Omega Seamaster Polaris Chronograph, reference TB 378.0885.
The serial numbers are:
  • Case: 50001xxx
  • Movement: 50003xxx
I would appreciate your opinions on two points:
Q1.Is this combination of case and movement serial numbers plausible for this reference?
Q2.Does the movement in the attached photos appear to be a genuine Omega Calibre 1154?
Any insights would be greatly appreciated.
The 1154 came in both "yellow" and rhodium versions.
I would expect that the serial numbers on the case and movement should be the same, so it's possible the movement was swapped at some stage.
