Then your watchmaker tests at full wind in 5 positions (preferably 6) and get those within, say, a 12 second variation - for example, fastest rate could be dial up at +15 seconds per day and slowest might be crown down at +3 seconds per day. This would give you the same accuracy as a 561 Constellation but, you have to take isochronism into account and a 561 runs close to full wind a lot of the time because of it's auto winder. So, you need to be sure that it's still running in a good spec after 24 hours, again in 5 positions - you do this for a 561 as well just in case it's not on full wind. This will be far more than a typical service from many places, virtually all in fact as usually you see a dial up test only.
Having gone through all that, you wind it each day at the same time and wear it for a week or two, noting the variation and go back to your watchmaker who might then shave a few seconds per day off using the micro regulator.
It's an interesting exercise and not too bad if you're a watchmaker with time on your hands but, if you're paying it won't be cheap. Of course, if you really want accuracy on a budget, choose a quartz
Hope this helps, Chris
