Full link - 114ST1501
1/2 link - 115ST1501
Note that there is one small "gotcha" on these. Depending on the time frame the bracelet was made, the tubes that go in the links with the pins are different diameters - some 1.2 mm and some 1.3 mm. You would have to measure the tubes to determine which size is needed if you need any...
