Case and movement that it's for? If you can provide more detail, I'll see if one is available. Cheers, Al
It's for the Speedmaster mkii 145.014 and the movement is an 861. Thank you very much I apreciate it!
I assume by reduction ring, you mean the ring between the movement and the case? If so, it's actually called an enlargement ring - part number is 079LC08610A, and it is still available from Omega. If that's not what you are after, then I need more details about the part you need - I see nothing on the case parts that has a number 9028 listed. Cheers, Al
Hi. I think 9028 is the tool for installing/compressing the o-ring for crystal installation in the case. Cheers
Ah...thanks for the clarification Stewart. Full part number for that is 5021409028, and it's no longer available from Omega. Either jury rig something up, or check on eBay as they do show up from time to time. Cheers, Al
