Hi , Posting pics of omega PAF 2996 with broad arrow hands . The movement on these watches are the same as in 2914s . The movement serial number are mix and match with 2914s . The cannon pinion, hour wheel , centre second pinion are a bit longer than the standard cal 285 movement. The longer version parts are used in the railmasters in order to accommodate 1mm thick dial. Regards
