Omega Moonphase disc patent
From this link, Omega states that:
At 6 o'clock is the accurate Moonphase indication, which features a blue enamel aventurine glass Moonphase disc (patent pending) with near and far sides of the moon in Sedna™ gold.
What part is in "patent pending" state? Is it the Moonphase complication (require adjustment each 122 years) or the "blue enamel aventurine glass Moonphase disc with near and far sides of the moon in Sedna™ gold"?
Publication number: 20190338425
Abstract: A method for fabricating a timepiece component partly formed of aventurine, including providing at least one piece of aventurine formed of a mass of coloured glass containing copper crystals scattered throughout the mass; grinding at least one piece of aventurine to obtain a granular powder; depositing at least part of the granular powder on a surface of a support intended to receive a decorative coating; then introducing the support with the granular powder deposited on the surface into a furnace and melting this granular powder so as to obtain, after removing the assembly thus obtained from the furnace and allowing the assembly to cool, an enamel layer made of aventurine which covers the support surface. The timepiece component is, for example, a dial, a moon phase disc or a bezel.
Type: Application
Filed: April 11, 2019
Publication date: November 7, 2019
Applicant: Omega SA
Inventors: Claire MCGILL, Gregory KISSLING
source: https://patents.justia.com/patent/20190338425
Type: Application
Applicant: Omega SA
Thank you!
I searched that site with the moonphase term with no luck. Sounds like my searching skill is too bad.
