The case isn't gold filled, it's 20µ electro plate, and if you look at the inside of the lugs and the side of the case there is considerable wear.
The case tab also shows evidence of moisture in the watch.
The stem is also badly bent, so a new crown and stem, and possibly a correct crystal should be factored into your total outlay (not to forget the cost of a proper servicing.
If you can live with the case wear it's a pretty watch but as
@hoipolloi said, anything above about $200/$250 is going to put you behind the 8 ball.
