Hello to all. I've been looking at this vintage Omega and i have two doubts regarding the same: 1. After googled the reference 166.0209 i only see Seamasters with day/date, and none Geneve; 2. Could it be redialed? Thanks in advance.
Hi there, I own a couple of Genèves and I can tell you the movement 1010/1012 is the one from Genèves. I would think that it was swapped the case back honestly....
BTW, looking at the pictures i see a 1021 movement instead of the 1010/1012. Is it suposed to be that way?
1021 is a chronometer grade movement and should be seen in a Constellation or a Seamaster chronometer, so methinks Dr Frankenstein could have had a hand in this.
I think this watch has been made out of pieces. The movement from one watch, the case back from other, the dial from a third one, and so on... Nevertheless, i'll ran away from him!
