Glenn,
I'm currently having the same problem, which is: the movement is not tightly set into the case allowing it to shift; a 1mm shift is enough to unseat the crown portion of the stem. Then the crown and it's stem portion come out when pulled. This is the first time I've opened a Dynamic, so I'm unsure how to set the movement securely into the case when reassembling.
Have you made any progress with yours?
Walt...
