Omega Constellation Globemaster Master Chronometer 39mm 130.30.39.21.02.001
For sale is a beautiful Omega Constellation Globemaster Master Chronometer ref. 130.30.39.21.02.001.
Features a perfectly sized 39mm stainless steel case with tungsten carbide fluted bezel, silver pie-pan shaped dial, a date window at the 6 o'clock position, and anti-magnetic resistance to fields greater than 15,000 gauss.
Powered by the Omega Master Co-Axial caliber 8900, which beats at 25,200 vph, contains 39 Jewels & has an approximate power reserve of 60 hours, courtesy of twin barrels mounted in series. The movement also features Omega's Si14 silicon balance spring that improves resistance to shock and magnetism.
COSC chronometer / Swiss Federal Institute of Metrology (METAS) certified Master-Chronometer.
The transparent sapphire case back features a medallion with Omega's Constellation emblem and provides visibility to the rotor & visible bridges, which are decorated with a unique wave finish.
Includes the watch only on bracelet that should fit up to a 7.75 inch wrist. Absolutely mint condition and recently regulated - No issues. Original MSRP $7000.
Asking $3,995 shipped via wire. Located in NYC for local inspection.
Thanks for looking!
