I don't know where you might be able to find that 40-year-old chip. That was designed to handle an odd frequency. Almost all the manufacturers have now settled on 32,768Hz. And if there was physical damage to the board, I would be careful to check the other parts. Are the coils good?
All the circuit does is move the resonator. After that, the resonator turns the index wheel with a very sensitive ratchet and pawl system (which was designed to run on the 1.35V mercury cells which are no longer available).
So simple (maybe for you) repair of the PCB might just be the beginning of the restoration.
Steve
