just received watch yesterday. Having trouble finding info on this calibre 613 for my omega Geneva. Appreciate if I can get some information/specs on movement please.
Well, first piece of relevant information is that the 613 is a date movement, so.... Are you sure it's a 613?
Well, looks like you have yourself a franken watch. In any case, the movement is a manually wound movement with date, 12 1/2 lignes in size, 17 jewels, 19,800 A/h, with a 38 hour power reserve. Generally speaking they are reliable and accurate if not in terrible shape. Your watch looks like it has some rust, may be in need of a service, and has had some parts replaced from a donor watch I suspect. In a word it looks rough. Hope this helps. Cheers, Al
Redone dial also, and as already told the dial should have had a date window if it was to fit the caliber 613 with date. Do you have the reference number form the inside of the caseback?
