Dear All:
I just received an Omega Beta 21 in seemingly great condition, but upon opening the case back, besides the gasket having turned to goo, the battery retaining prong and screw has an extra spacer!
The battery that was in the watch was an Energizer 357/303, which is NOT the current correct replacement battery for this movement, according to Omega. The Renata 386 is the proper replacement.
The Energizer 357 which is in my Beta 21 is thicker than the correct Renata 386 battery.
I thought that i'd just take out the incorrect battery Energizer 357 and put in the correct Renata 386 and i should be fine. Wrong! Upon taking out the Energizer 357, i put in the Renata 386, only to discover that even screwing the battery retaining prong's screw all the way in, the prong was much too high, i.e. away from the battery's + surface. Upon closer inspection, there is a spacer(!) in the screw! (Pictures attached)
I thought that this could not be correct as Omega's own service pages said Renata 386 is the correct replacement battery.
the Energizer 357 is thicker, so the spacer made that work.
while the spacer has the same copper color as the battery retaining prong and the screw and thus looks "original", i am guessing that it couldn't have been original and that someone had added the spacer in.
may i please ask the good folks here if that is true please? What should i do?
@Tom Dick , et al: I would be most grateful for any knowledge, advice, if you don't mind.
Thank you.
