  1. kov Trüffelschwein. Dec 6, 2016
    Inside caseback from my 3592.50 above :
  2. Frederic_gva Dec 6, 2016
    So reference is 3592.5000 or 345.0808 ?
    It is not clear, even on the extract.. ?
  3. kov Trüffelschwein. Dec 6, 2016
    Both :rolleyes:
    One is the ref the other is the PIC ;)
  4. Frederic_gva Dec 6, 2016
    Ok so we both have the same exact watch
    Your warranty card has credit card format or paper document?
    What is the PIC ? (forgive my lack of knowledge)
  5. Archer Omega Qualified Watchmaker Dec 6, 2016
    Sort of...from the Extranet...
    Watch SP MOON ORIGINAL Gents
    Ref. 35925000
    Omega does call this the reference number. The reference number is for the whole watch, so under that number you will find dials, hands, case, movement, bracelets/straps, etc. If one thing changes, so from a bracelet to a strap for example, the reference number will change.
    The case number (or case reference) only tells you about the case, not anything else. The 3450808 is a partial case number...full number is 055ST3450808. This identifies it first as a case number (055), the case material (ST = Stainless Steel), and then the rest describes the other specifics. That case is obsolete, and is replaced by 055ST1450808, which is a case used on 8 different reference numbers, so 8 different watches. So saying the case number = reference number is not really applicable to modern watches like it is with the older vintage stuff, because one case can be used on many watches.
    fskywalker, kov and Frederic_gva like this.
  6. Frederic_gva Dec 6, 2016
    Crystal clear thanks
  7. Frederic_gva Jan 26, 2017
    @ricky3334 did you finally buy it ? or another one ?
  8. Faz Jan 26, 2017
    Could it be the Italy only version 345.0808? Any engravings on the side of the case?
    https://omegaforums.net/threads/ome...-25th-apollo-xi-italy-3500.49889/#post-600110
  9. fskywalker Nov 19, 2018
    Wonder if OP finally bought it::popcorn::
  10. kov Trüffelschwein. Nov 19, 2018
    fskywalker likes this.
