If you really want to learn watch repair, this is not the way to go about it. If you just start taking apart whatever watch is in front of you with no prior experience, you will learn a lesson, but it won't be the one you want. Even the web site you are using says this:
"The 1611 has not been designed for repairs but you might try your luck."
"Trying your luck" as a rank beginner on a watch that is not easily repaired, and one that parts are scarce for, is not a recipe for success. One slip can damage the electronic module, and that is a discontinued item, as are several other key parts. So this is most certainly not an ideal situation for someone to learn repair techniques, as the risk is far too great for inexperienced hands. You are far more likely to brick this movement than to fix it.
There is a reason that watchmaking schools start students off slowly, with large movements taking things step by step, and fully understanding one thing before moving to another. That is pretty much the opposite of what you are doing here.
I'm all for people learning, and am willing to go above and beyond to assist people who are serious about learning how to repair watches, but I gave you the best advice for your situation - find a watchmaker who knows what they are doing before you damage something.
