It's the screw that holds the shock absorber assembly in place on some older versions of this and the 550 series movements. On a more recent movement where the Incabloc assembly presses into the main plate, you won't have this screw. It's normal and doesn't interfere - I'm sure you could see that it wasn't contacting anything as you were taking it apart, right?
