Hello to all OF members. Looking for correct movement Ref. Omega 2765 4 CS, 2764, 2771 Any help will be appreciated
Using the search function on this forum should have gotten you this: https://omegaforums.net/threads/omega-seamaster-cal-344.56920/ I saw the listing for that case online and think you are taking on a rather expensive project, unless you already have a cal. 344 movement and a dial. Good luck with your project. gatorcpa
Thank you, gatorcpa. As you see on case back it's stamp with CS, cal.344 is sub second movement It must be something else i think, Cal.351 maybe
It is double stamped. That case is used with both centre second and sub second movements. In fact it looks triple stamped.
