Hi, welcome to the forum.
My suggestion would be: keep this money and see if you can put a bit more into a much better example. You can probably have a much stronger condition for around double.
This one has serious condition issues. The dial may have seen some water ingress, or at the very least the « patina » is quite unattractive in my opinion. The case may even have a small hole in it.
The seller has its fingers all over the movement, which doesn’t look promising on this front, and it show quite a lot of wear on the bridge.
If you have to put a service into the watch soon, then it won’t sound so cheap anymore.
So I’d personally pass.
